Kupe's Zodiac 650B
Date:  7-13-2015
Number of Hours:  1.00
Brief Description:  Spark Plug Leads 1
Began the process of installing the spark plug wires this morning. Step one was to reconfirm the cylinder assignment to each ignition coil. I confirmed the cylinder assignment on each coil pack using the factory installation manual and labeled them accordingly. Next, I labeled (arbitrarily) one coil pack as "Intake" and the other as "Exhaust" to describe which side of the cylinder their respective spark plugs would be located.
After that, I labeled the baffles with the cylinder numbers and the Intake versus exhaust position of the spark plugs on each side. Then I began feeding the coil of wire through the opening at the back of each baffle and sizing the length of wire to be able to connect from the same cylinder designated on the coil pack to the proper spark plug on each cylinder. Snip! Wires were cut and labeled (so I don't forget where they're supposed to go) until I had all 8 completed.
Next up: Attaching connectors to the coil pack end of each wire.
Right side (
Right side ("Exhaust") coil pack and cowling labeled with cylinder number and cylinder side.
Right side cables cut to size and individually labeled.
All 8 wires cut to length and individually labeled.
