Kupe's Zodiac 650B
Date:  7-12-2015
Number of Hours:  1.00
Brief Description:  EGT Probe Installaiton
Installed all four exhaust gas temperature (EGT) probes this morning. The Dynon-provided probes make this a straightforward task. All that was needed to be done was:
1. Measure along each exhaust pipe to a point between 3 and 8 inches from the cylinder where the pipe is on a straight run.
2. Mark the point with a sharpie. I settled on 6 inches on all 4 pipes in my installation.
3. Drill a 1/8" hole into each pipe ensuring the hole isn't pointed back at the engine in case the probe ever comes loose.
4. Install the probe into the 1/8" hole and secure it with the provided steel hose clamp.
The hardest part was drilling through the steel pipes - each hole took a couple of minutes of straight drilling using moderate pressure, medium speed, and cutting fluid.
Close up of right side probes
All 4 probes visible from the front.
Right side probes with the whole engine in view.
