Brief Description: More Fuel Lines / Air Oil Separator Hoses
Fabricated and assembled the fuel return line. This line exits the engine on the right side and travels aft along the upper engine mount. A one-way flow valve is installed in the line to prevent return fuel from running back into the engine in the event of fuel pressure failure (engine failure, electrical failure or just simply shutting off the engine). Downstream of the one-way valve, the hose continues aft through the firewall to where it will eventually be connected to the electric fuel selector valve.
I also measured, cut, and installed the two hoses that connect the oil air separator with the engine.
Fuel return line running along the right side of the mount.
