Brief Description: Ignition Coil and Regulator/Rectifier
Installed the mounting plates for the 2 ignition coils and the regulator/rectifier. The mounting plates are attached to the engine mount via 4 adel clamps and are designed to hold the coil packs for the ignition system. I was reminded again why I avoid using adel clamps, but finally managed to set up a system to hold the clamp and bolt in place with needle nose pliers while attaching the nut with washer. By the time I had the 8th clamp in place, I was gaining some proficiency.
Once the 2 mounting plates were in place, I attached an ignition coil to each one with AN4 bolts. Lastly, I attached the regulator rectifier to the right (passenger) side mounting plate. Once everything was in place, I torqued down all the nuts to AC43-13 standards and hit them with some torque seal.
Right side ignition coil attached to mounting plate.
A closer look at the right side ignition coil.
Left side ignition coil and the regulator/rectifier on the "back" side of right mounting plate.
