Began installing brake lines. This involved several setup items like:
- Reinstalling the brake master cylinders so that the brake line is oriented toward the right rather than toward the front. - Reinstalling the master cylinder to the cabin floor with the proper bolts torqed correctly. - Installing the final bolts that connect the toe pedals to the master cylinder actuator and adding a cotter pin. - Adding compression fittings to each of the master cylinders. - Running brake lines from each master cylinder, down the center of the cabin, through the center hole of the wing spar, then one under each seat (left/right). - Drilling holes in the side of the fuselage just forward of the landing gear bracket to allow the brake line to exit the cabin area.
I haven't integrated the parking brake yet because I'm still not precisely sure where I'm going to attach it to the floor. I'll know more as I run the fuel lines.
Left side rudder pedals fully installed with brake lines running from them past parking brake.
Brake line exit point on right fuselage. From here to aft edge of gear to the brakes.
