Finished installing the Fuselage Step Fairing. Started by performing a little filing where the access door and the fairing meet to improve the fit. Then I cleaned, deburred, sanded, and painted the Fuselage Step Fairing and fuselage door hinge with corrision control paint. I also deburred the rivet holes on the fuselage inside and out.
Once the paint dried, I reassembled the step fairing and door hinge and riveted them in place. I then clecoed the fuselage door to the other half of the hinge to reconfirm fit. I will remove the door to keep it out of the way until final assembly.
Fuselage Step Fairing riveted in place. Fuselage access port just to the aft behind the visible hinge.
Step Fairing in place with fuselage door temporarily installed and closed.
From behind. Temporarily installed fuselage door in the open position.
