Kupe's Zodiac 650B
Date:  4-5-2015
Number of Hours:  1.50
Manual Reference:  6-B-3
Brief Description:  Fuselage Door Fitting
With the Fuselage Step Fairing fitted, it was time to finalize the fit for the fuselage door. The fuselage door sits just behind the step fairing and provides ready access to the inside of the aft half of the fuselage for inspections and maintenance. The door had been loosely fit back when the rear fuselage bottom skin was assembled, but I delayed further fitting until the aircraft was up on its legs.
The fitting went well with a some filing required to alleviate a little interference between the door and the fuselage step fairing when opening the door.
