Brief Description: Drill Rear Canopy Skins to Bubble
Reinstalled the rear canopy bubble to set the rivet line for where the rear canopy skins attach to the canopy bubble. After setting an 80mm pitch rivet line (pilot hole) into each rear canoopy skin where it meets the bubble, I reinstalled the skins, and carefully marked through the rivet holes into the canopy bubble by turning the pilot hole drill bit for a couple of rotations. I then removed the skins and drilled through the canopy using a 5/32" acrylic drill bit. After a quick deburring, the rear canopy bubble is now ready for final assembly.
Right side rear canopy bubble with holes drilled for rear canopy skin.
