Kupe's Zodiac 650B
Date: 7-14-2014
Number of Hours: 3.00
Manual Reference: 6-C-6
Brief Description: Fit Rear Canopy - Begin Canopy Cleanup
Drilled out the rear canopy to the aft rear hoop. The left side lower edge hung down slightly too much so I trimmed off about 10mm for a better fit. Then I set the rear canopy bubble into place and matched drilled through the plexiglass to the aft rear frame.
In order to check for final fit, I reinstalled the rear top skin to see where it touches the rear canopy bubble. I was pleased to see there will be no need for additional trimming to get it to fit. I then taped the rear canopy skins into place to check for fit. These skins help form a smoothly curving transition from the rear top skin down both sides and forward along the baggage area. Again, these look like they'll fit fine.
Next, I updrilled all the remaining rivet holes that connect the various canopy hardware to the canopy frames (rear canopy gusset, front canopy bracket, front canopy frame gusset) and I drilled out the rollbar to its final attachment sizes: 4 AN3 bolt holes to the upper longeron and 4 rivet holes in its upper cradle to attach to the aft rear frame. Lastly, I disassembled the entire canopy structure to begin the deburring, filing, sanding, painting, and heat shrinking in preparation for final assembly.
The rear canopy bubble drilled and clecoed onto the aft rear frame.
Added the rear skin back on to check fit with rear canopy. No additional trimming required.
Canopy completely disassembled for cleanup and paint.
