Installed the canopy side frame handles. This required some filing to round off the sharp edges on the aluminum extrusions provided by Zenith, marking & drilling a rivet line on both handles, then match drilling the rivet lines onto the steel canopy side frames.
While I was at it, I drew out and drilled the rivet line for the canopy along the rest of both side frames.
Right side canopy frame with the canopy handle clecoed in place.
The right side canopy frame with the rivet line drilled out.
