Kupe's Zodiac 650B
Date:  6-17-2014
Manual Reference:  6-C-5
Brief Description:  Canopy Locking Mechanism Complete
Reassembled the now-painted canopy locking mechanism and tested it for appropriate range and ease of movement by:
- Bolting the two end tubes onto the torque tube.
- Re-attaching the two bearings to the inside skin under the upper seat back.
- Inserting the inside locking handle through the seat back and seating the torque tube ends into the bearings.
- Inserting the external latch through the left side skin, bearing, and end of the torque tube.
- Attaching the handle to the fuselage with two bolts.
- Attaching the two arms to the two latching mechanisms with cotter pinned bolts.
- Adding the ball to the end of the inside locking lever.
The canopy locks are complete, minus a few bearing rivets...
Pilot side canopy locking mechanism fully installed. The flap motor is also visible at the bottom.
Passenger side with the inside locking lever (foreground) and latch (background) fully locked.
External locking handle with the keys inserted.
