Drilled out the canopy torque tube to the precise position measured during test fitting so that both end tubes are bolted in the correct position when fully open and fully closed.
Then deburred and filed all of the steel parts (tubes, ends, arms) and sanded them completely to ready them for painting. Painted them with undercoating and final flat gray paint (to match the interior fabric) and left them to dry for the day.
I also deburred, filed, sanded and painted the two bottom brackets for mounting the gas springs that hold the canopy up when it's open.
