Swaged and installed the lower elevator cable onto the control stick
Drilled out electrical pass-through holes that provide a path for the wing wiring (position lights, trim, landing lights) to enter into the fuselage and inserted nylon grommets.
Looking down into the open armrest: Lower elevator cable (foreground) and upper (background).
All the longitudinal cables running through the fuselage.
Right side just behind middle spar: Electrical pass-thru hole with grommet.
