Kupe's Zodiac 650B
Date:  5-30-2014
Number of Hours:  2.50
Manual Reference:  6-G-3
Brief Description:  Spring (Main) Gear Test Mount
Started out the day by grinding a notch into the spring gear to accept the upper-aft bolt for the left brake assembly (as I previously done on the right brake assembly).
Next, after having thought about this for weeks, I finally came up with an idea for mounting the spring gear. The spring gear is a 7-foot-wide, 45 pound hunk of aluminum that requires 4 carefully placed notches in it to accommodate the 4 gear mount bolts already attached to the fuselage. This piece is unwieldy for two people and since I pretty much run solo in my building, this was a challenge I'd been mulling over for a while. I needed the ability to move (roll), rotate, and raise/lower the gear while keeping at least one hand free and I was having a hard time imagining such a device without sending a wad of cash on it. Today I realized the answer was underneath me he whole time: My trusty work bench stool!
So I made a wood platform out of 2 x 4 scraps scavanged from various Zenith shipping crates, and placed it on the chair, then added the spring gear to the top of the platform. From that point is was almost a 1-finger effort to maneuver the spring gear around the garage and raise/lower it using the hydralic seat height adjustment on the chair. One hour later, after some serious notch grinding, I had the gear custom fitted to the gear mounts and temporaily mounted using the reast of the mounting hardware.
Left brake assembly installation complete.
Home made spring gear installation truck.
Spring gear mounted in place.
