Continued work on the nose gar assembly by attaching the lower bearing mount and test fitting the bottom bearing to mark pilot holes where the lower attach bolts will fit.
Also finished off all four engine mounts by taking the newly painted steel parts and attaching them with bolts and torquing the bolts down to spec.
Front of firewall: Bottom bearing in position resting on top of the lower bearing support.
From below the firewall: Lower bearing support with bottom bearing resting on it.
Behind the firewall. 2 upper engine mounts installed. Right lower engine mount visible on far side.
