Kupe's Zodiac 650B
Date:  5-5-2014
Number of Hours:  1.50
Manual Reference:  6-B-21
Brief Description:  Rear Top Skin Drill Out
Drilled out the rear top skin. Beginning from where I left off the previous session, I drilled out the top skin from the inside out. This was accomplished by unclamping one side of the top skin so that I could lean inside over the fuselage side then use an angle drill to drill out through the pre-drilled holes in the flanges of all three bulkheads. When I finished the first side, I unclamped it, reclamped the other side into position, then did the same thing all over again. That was quite a bit of acrobatics especially when reaching across the fuselage to the far side of the baggage bulkhead, but it all turned out fine.
From the right front, rear top skin drilled out and clecoed.
From the right rear.
All the turkey quills sticking out. Top skin is tucked inside side skins for eventual match drilling.
