Kupe's Zodiac 650B
Date:  4-13-2014
Number of Hours:  5.00
Manual Reference:  6-B-5, 16, & 23
Brief Description:  Rear Frame Channel, Upper Seat Back
A bunch of reassembly today with updrilling to final rivet size, deburring, filing and sanding throughout. In order, here are the tasks completed:
- Reinstalled firewall and updrilled the bottom to final rivet size.
- Reinstalled replacement front upper longerons.
- Re-leveled the entire airplane (took close to an hour to get just right).
- Updrilled the rear torque tube bearing support where it attached to the floor (now that I can get underneath the airplane).
- Deburred, filed, sanded rear torque tube bearing support and reinstalled.
- Updrilled upper seat back then deburred, filed, sanded and reinstalled.
- Updrilled rear frame where it attaches to the floor then deburred, filed and sanded the entire rear frame assembly.
- Added rudder and elevator fairleads to the rear frame then reinstalled.
Firewall and longerons back on - fuselage level and square again.
Upper seat back reinstalled after updrilling and cleanup.
Rear frame reassembled with fairleads installed.
