Kupe's Zodiac 650B
Date:  3-15-2014
Manual Reference:  6-B-15
Brief Description:  Install Front Seat Panel
Measured, trimmed, and set rivet lines for the two forward seat panels. There were 3 rivet lines each: One attaching to the wing Center Spar, one line attaching to the Gear Channel, and one attached to the side skin. Once I drilled them out at pilot hole size, I updrilled all lines to final rivet size to regather the clecoes.
I also updrilled the rivet line where the rear fuselage bottom skin, gear channel, and seat back all share the same rivet line. You can see this rivet line in images 1 and 2 - the line just aft (to the left) of the forward seat panels.
Forward seat panels attached to Center Spar, Gear Channel, and skin
Looking forward.  The gap between the seats will contain the armrest.
From the outside - a new rivet line on each side skin next to the yellow line I added to the pic.
