Kupe's Zodiac 650B
Date:  2-23-2014
Manual Reference:  6-B-18 & 19
Brief Description:  Seat Back Side Angle/Flap Gusset
Installed both seat back side angles. Like the previously installed center seat back (right side of image 1 / center of image 3), these angles set the inclination of the seat back and provide a signficant amount of stiffening by connecting the rear seat panel to the side skins with a densely pitched rivet line. On the right side there is also a thick gusset integrated with the seat back side angle that will support the linear actuator mount for the flap motor. I guess I'll really be able to use the seat-of-my-pants to tell when the flaps are in transit!
Right side seat back side angle attached (at the far end of the rear seat panel)
Right side seat back side angle with flap gusset.
Seat back all assembled.  Top of the center spar in the foreground at the bottom of the pic.
