Re-squared the fuseage again and attached the center seat back to connect the upper seat support with the rear seat panel. This locks in the upper seat support in the middle (the two ends connected to the skin via L-angles) and sets the rear seat panel at the appropriate angle.
I also clamped the three bulkheads in place to check for fit and to see if the baggage floor position was correct with regard to the most forward bulkhead also known, appropriately, as the Baggage Back Bulkhead.
Center seat back connecting upper seat support to rear seat panel. Center spar in the foreground.
Test fit of the bulkheads. Biggest one defines aft edge of baggage area and (eventually) canopy.
