Kupe's Zodiac 650B
Date: 2-1-2014
Number of Hours: 3.00
Manual Reference: 6-B-7 & 8
Brief Description: Firewall Updrill, Final Prep
Pressed hard to finish the firewall today. Yesterday my replacement center firewall stiffener arrived in the mail, so today I set about to fitting the gear gussets and the firewall stiffener doubler to the new center stiffener. Next, I drilled out the upper bearing for the nose gear which fits inside the top stiffener. Then I updrilled all the pilot holes to their final rivet size, trimmed some of the pieces to reduce their sharp angles, then took the whole thing apart. After about 2 hours of deburring, filing, and removing the factory labels, I had everything ready to paint with CORTEC corrosion control paint. Painting took about 5 minutes.
Tomorrow is a RIVET DAY!
All the firewall pieces after updrilling to final rivet size, filing, and deburring.
All the parts after de-labeling, sanding, and painting.
