Brief Description: Brake Cylinders, Toe Brakes Install
Measured out and drilled the brake cylinder supports, brake cylinders the toe pedals and the toe pedal hinges. Getting everything lined up was a real Rube Goldberg of clamps and clecoes and hammering the toe pedal hinge to follow the curve of the pedal was a unique experience. All in all it appears everything fits together well. Next challenge will be to attach the toe pedals to the rudder pedals using steel rivets.
Viewed from the front, the left & right brake cylinders attached to the toe pedals.
Viewed from the pilot position, the two brake toe pedals
