This morning I fabricated and drilled out the two diagonal firewall braces that attach to the aft (cockpit) side of the firewall. I also installed the rear channel.
I also mis-drilled the center stiffener when attaching the gear gussets, so I sent off for a replacement from Zenith - should arrive in a few days.
