I was joined by my daughter this morning to rivet up the rear fuselage section. Step one, crank up the heater in the garage. Step 2, make sure everything's lined up just right using the laser leveler. Step 3, commence riveting. There were a lot of rivets in the rear fuselage, but with two of us on the job we made short work of it. Thanks Shannon!
Laser leveler in the foreground. A close look shows laser reflection all along the center line.
Special guest riveter, braving the cold elements of the garage, hard at work.
