Kupe's Zodiac 650B
Date:  1-6-2014
Manual Reference:  6-B-3
Brief Description:  Right Rear Side Skin Fitting
WIth a balmy 38 degrees today, the garage was almost hospitable. Today I drilled out the right rear side skin to the horizontal tail frame, the lower longerons, and added in all the diagonal skin braces as well.
Once finished with the right rear side skin, I moved all my veritcal supports to the other side of the workbench and began the preliminary fitting of the left rear side skin.
Right rear side skin after drilling out the longerons, horizontal tail frame and diagonal braces.
Right rear side skin from the inside after drill out.
Left rear side skin after preliminary fitting.
