Kupe's Zodiac 650B
Date:  12-21-2013
Number of Hours:  1.50
Manual Reference:  6-K-1
Brief Description:  Right Wing Tank Final Installation
Brought the finished (and leak-checked) fuel tank up from the basement for final assembly into the wing. The fit remains just right and the extra cork I added makes the fit seem even more glove-like. I fuel-lubed the fittings one last time then threaded both fuel hoses (feed and return) through the nylon-grommeted holes in nose ribs #2 and #1. I then pushed both hoses over their respective fittings and clamped them in place.
I crimped terminals to all the wire ends (ring tongue and tab as required) and then attached them:
1. From the wing tank grounding tab to the wing skeleton (ground).
2. From a fuel sender screw to the wing skeleton (ground).
3. From the fuel sender tab through a nylon-grommeted channel through nose ribs #2 and #1 eventually leading to the fuel quantity indicator.
Right wing tank with fuel feed (lower) and fuel return (upper) fittings and hoses installed.
Right fuel tank ground, fuel sender ground, and fuel sender indicator wires installed.
