Kupe's Zodiac 650B
Date:  12-18-2013
Number of Hours:  1.50
Manual Reference:  6-W-8
Brief Description:  Right Wing Top Skin Debur/Paint
Finished deburring the top skin rivet holes and edges and sanded all the "inside" rivet holes. I ran the blast heater for about 40 minutes to get the garage temperature up to 60 degrees to apply the Cortec paint. Painted up the inside of the top skin and the inside of the leading edge skin as well as the top side of the nose ribs. Next up: The top side of the rear ribs.
"Outside" of the top skin with masking tape over rivet holes to prevent paint bleed-thru.
"Inside of the top skin with the paint freshly applied.
After the paint has dried.  It is literally clear - all you can see are the sanding marks.
