Kupe's Zodiac 650B
Date:  12-14-2013
Number of Hours:  1.00
Manual Reference:  6-W-9
Brief Description:  Right Wing Nav/Strobe Wire Connector
Assembled the Molex connector for the right nav/strobe light. This connector will allow me to remove the nav/strobe light from the wingtip end of the wiring in case it needs replacing or maintenance.
I also took the time to remove the flap from the left wing which is stored up on the ceiling of the garage. After learning about some techniques folks are using to pull (and replace) the piano hinge pin on their flaps, I decided it would be easier on the flaps if they were stored separately from the wing.
Right Nav/Strobe light wire connector loosely plugged in.
Left wing, hanging from the garage ceiling, with the flap removed.
