Brief Description: Right Wing Final Wiring, Top Skin Debur
Finished off the wiring for the right wing by adding a couple of adel clamps to the outboard side of the 9th rear rib and a pass-through grommet through the main spar lightening hole.
I also began the arduous job of deburring all 475 (or so) rivet holes in the right wing top skin and 95 holes in the top half of the leading edge skin. Over half-way finished with that task now.
Nave/Strobe wire bundle along the 9th rib adel clamps and through the main spar lightening hole.
Specially fabricated wire channel through main spar lightening hole.
