Kupe's Zodiac 650B
Date:  12-6-2013
Number of Hours:  1.50
Manual Reference:  6-WLO-1, 6-S-3
Brief Description:  Wing Locker Fasteners, Flap Gap Stop
Finished off the last 4 dzus fastener springs today. I then made "clips" for the dzus fasteners by cutting out rings from a discarded plastic milk carton. These clips keep the fasteners attached to the wing locker door when the fasteners aren't locked - hopefully preventing me from losing any. It seems like a cheap mod, but it's solid, inexpensive, and effective.
After finishing the wing locker door fasteners, I cut out an 1/8" thick piece of plastic bearing material that will rivet in to the aft channel and rear top skin. The purpose of this piece of nylon is to act as a stop for the flap to keep it from rubbing up against the rear channel. I was shooting for 6mm spacing - which I nailed.
Dzus fasteners with
Dzus fasteners with "clips" to keep them attached to wing locker door.
Wing locker door with all dzus fasteners completed.
Flap gap stop with requisite 6mm spacing between flap and rear channel.
