After a quick trip to Home Depot to pick up fabric washers, I attached the fuel sender to the right fuel tank. I made sure everything was well coated with fuel lube, then inserted the sender assembly into my previously cut out hole, and screwed it all into place. I'll leak check it sometime this week. I also beefed up the cork on the tank using the additional cork I had Zenith send me last week.
Having finished with everything I could work on on the bottom side of the wing, I flipped it back over right side up to finish the wing locker, work on the fuel tank installation, and drill out the leading edge skin on top.
Lastly, I took some time to reorganize my parts bins by re-labeling all my shelving to house the parts for the fuselage I received the week before last. I'll be starting on that soon.
Fuel sender installed in right fuel tank. Leak check pending.
Wing back right side up with top skin installed ready for final tasks.
Fuselage parts organized and labeled on my shelving in the basement.
