Brief Description: Paint Aileron Balance Weights, Leading Edge Debur
Primed and painted the right aileron balance bar weights. These weights are added to the aileron balance bar in sufficient number to counter balance the weight of the aileron to help minimize aileron flutter. The biggest challenge to this task was raising the 38 degree garage temperature to above 50 degrees for the paint to work.
I also began deburring the right wing leading edge skin in preparation for attaching it to the bottom of the wing. I gave me something to do instead of watching paint dry.
Right aileron balance bar weights - primed and painted.
Right wing leading edge with the outside deburred and sanded.
