Began work on the right wing locker. As with the left wing, this involves cutting out a large hole in the otherwise pristin top skin. Once again, the Olfa knife does the trick quite nicely. After cleaning up the cut out a bit, I set a new rivet line for the locker door hinge drilled it out, then drilled out the hinge itself. Finally, I fit the locker rear wall to two L-angles attached to ribs #4 and #5 and added an extruded L-angle to the top of the rear wall to attached the top skin.
Right wing locker cut out between ribs #4 and #5.
Locker door hinge drilled out.
Rear wall clamped in position on the 2 new L-angles attached to the adjoining ribs.
