Brief Description: Fuel Line Upgrade, Re-Swage Aileron Cables
More prep for final closing and a couple of corrections based on my tech counselor meeting earlier in the week to include:
- Upgraded the fuel feed line from 1/4" to 3/8" which included expanding the hose opening through the nose ribs, adding larger nylon grommets to the hose openings, and installing a 3/8" hose nipple to the tank fitting.
- Accomplished wiring for the fuel tank (tank ground, fuel sender ground, fuel sender wire).
- Re-swaged the aileron cables to meet AC 43.13 standards.
- Installed jam nuts on all-thread aileron pushrod.
- Installed washers on pushrod attachment bolts on both the bellcrank end and the aileron end.
Upgraded fuel feed line. The fuel tank wiring is also visible here too.
Re-swaged aileron cables. Triple-swaged IAW AC 43.13.
