Popped the top side of the leading edge back up to remove, debur, file, sand, and paint the landing/taxi light housing. I then installed the two lights into the housing and clecoed the whole assembly back into the leading edge and riveted it in place.
While I had the leading edge opened up again, I added some more cork around the fuel tank fill opening for a better fit with the fuel cap housing.
I then re-closed the top half of the leading edge skin to finish the opening for the landing/taxi light (more sanding and filing) and to check the fit of the clear protective lens that fits inside the leading edge of the wing in front of the lights ... where I promptly broke it while trying to remove it during fitting! A new one is on order already. :(
...and the fuel tank fill opening needs another layer of cork too!
Landing/taxi lights, riveted in place inside the filed and sanded opening (without the broken lens).
