I got ready to install the fuel senders in both tanks today. First I measured the inboard ends of the tanks for the location of the fuel sender hole. I then transferred the distance from the top to the bottom of the tank at that fore/aft position to a piece of paper to make a template. Next, following the Zenith instructions, I took the fuel sender, and bent its float rod so that it will correctly measure the tank level.
Tomorrow I cut a BIG HOLE into each fuel tank.
The sender on the template in the "empty" position (bottom line) with an ohmmeter reading of 77.2.
Fuel sender in the full position (4 ohms). Note how it's right against the top line of the template.
