Brief Description: Nose Ribs Rivet, Leading Edge Skin Rivet (Bottom)
Got up early to reattach and rivet the nose ribs. After flipping the wing upside down, I clecoed the nose ribs back into place and riveted them - easy-peasy. I had lots of time left before work, so I moved on.
First, I painted the flanges on the nose ribs where the bottom portion of the leading edge skin attaches to them. I also painted the rivet line on the rear bottom skin whre the leading edge skin covers them. Then, taking the nose skin which I had already prepped back on 10 July, I re-clecoed it to the main spar and nose ribs. I then riveted the bottom half of the leading edge skin using A5 (big) rivets along the spar and A4 (medium) rivets through the nose rib flanges.
Nose ribs riveted to the main spar after flipping the wing upside down.
The leading edge skin clecoed in place with A5 rivets inserted and ready to be pulled.
The riveted lower half of the leading edge skin viewed from the wing root.
