Kupe's Zodiac 650B
Date:  7-12-2013
Number of Hours:  1.00
Manual Reference:  6-W-8
Brief Description:  Wing TIp Up and Top Skin Removed
Tipped the wing up onto its main spar while the nose ribs are off, I removed the top skin so I could access the inside easier. After vacuuming out the inside, I tightened the bellcrank swivel and the aileron actuator rod bolts to spec and started mapping out the wiring and tubing paths through the wing ribs.
