Filed off the wing locker cutout with a file to get rid of the rough edges from the Olfa knife. I then measured a rivet line just aft of the wing spar rivet line to attached the wing locker door hinge. After drilling out the skin, I clamped the hinge and a small block of wood under the skin and drilled through the hinge and clecoed it in place.
I then matched the hinge rivet line on the leading edge of the hinge to the aft edge of the hinge and drilled it out. Next I placed the wing locker door under the new hinge line to mark where to drill the door. Finally I drilled out the marked holes in the door and attached it to the aft edge of the hinge.
Closed wing locker door viewed from the front of the wing with the drilled out hinge visible.
Wing locker from the aft edge of the wing with door attached to hinge and held open.
Open wing locker door at the far (inboard) end of the wing.
