After a two week trip to China, I finally was able to get back into the garage and resume work. I still don't know what time zone I'm in - this work was accomplished at 3:00 a.m.!
Drilled out and riveted the lower wing skin protection plate. This part is used to protect the interior wing skin from inadvertant contact by the aileron balance arm which extend forward from the aileron into the wing. In the image below, you can see the protection plate is about 18 inches in from of the hole in the wing rear channel where the balance arm sticks through into the wing.
Wing sking protection plate riveted to the inside lower wing skin.
