I crawled around in the fuselage installing the frame and connecting the wirring. I wired the other molex and flipped the flaps switch. This this is sooooo cool. Flipping the down switch once, takes it to 10 degrees of flaps, then 20 degrees, then the final click of the switch looks like it might take it to 40 degrees (I'll have to connect the flaps to find out.)
You can either bring the flaps up all at once, or incrementaly.
