I seperated the servo wires that need to go to: ground - black - attached it to the grounding post power - red - connected it to the molex - circuit breaker disconnect - yellow - connect to disconnect switch on stick
green-blue-white/green-white/blue - Completed the forward wiring. Crimped on the pin, installed into the housing, added heat shrink, strain relief.
It was actually fun terminating some of the wires. The panel is starting to look doable.
