Dad came over again this afternoon and we talked through where to move the equipment too. I removed the grounding bar, the Dynon battery backup, and the fuel monitor. Then, installed the canopy and marked how low it come on the sub panel when it was all the way closed.
It was the first time I tested the release system and it worked perfectly. In fact, I won't even need the adel clamp to hold the arm. When the canopy is closed it locks it in place. I think I'll put a bit of plastic tubing on it so it won't vibrate.
I removed the canopy and went about installing the fuse panel, the fuel sensor and the grounding bar.
