I completed the wing servo wiring this evening. I ended up taking apart what I did last night and made sure the the wires from both the male and female connection passed through correctly. Although I was careful installing the pins, I worried about it a bit last night so just decided to make sure everything was correct. (It was.) The pin crimpers I purchased work much better than the ones I used in the workshop. (So does the wire stripper.)
