After securing the OAT wires down with the bolt through zip ties, I wasn't happy with the way they looked and worked. So, I removed them and went with the mounts that pull rivet to the bulkhead. They are more secure and you can remove or adjust the wiring without having to replace the whole dang thing.
After hooking everything up, I fired up the Dynon Skyview and the OAT appeared! Cool!
