Before I get to carried away with putting everything back together again permanently, I'm going to install as much of the equipment and switches as I can.
So, I installed the wig-wag switch, panel lighting switch, and flap controller switch. (Running the wires to each.)
I also installed the main ALT power wire from the breaker to the EXP bus.
