This afternoon I worked on enlarging the hole through the back subpanel for the avionics. I had the wiring done and I'll need a larger opening below and above the holes I cut.
I spent most of the time trying to figure out how little I could trim. I used the Rockwell SonicCrafter to make the cuts
