This evening I worked on getting the fit of the canopy better. I probably had the canopy on and off 50 times as I trimmed a bit here and a bit there. I am using a small belt sander as the fitting gets closer.
I am working to get the fit good enough to drill the back canopy frame. It has to be adjusted up against the plexiglass.
