Brief Description: Carb Heat replacement - air box
After reading about some of the issues with the carb heat unit that Vans sells, I decided to order the setup from RobinsWings.com. They are stainless steel instead of aluminum and the heat muff should do a better job bringing in warm air.
Carb air scoop connection: So, I drilled the rivets out of the old one, then worked on getting the new to work. The holes I drilled were close enough that I was able to file them to fit the holes in the air box.
