Brief Description: Baffle - Seal 4 - Checking cowling fit
Before I finish the front baffling material, I want to make sure what I've done so far will work. So, I test fit the cowling a few times. I had to use tape to pull the baffling material into place under the cowl. I tried a number of methods... but nothing seemed to work.
I used a flashlight to take a peak out how things were fitting and it looks like it is sealing things up pretty tight.
